problem with steering
hi have problem, when you floor the car it seems to pull quite badly to left, then right then back off accelerate normally and is ok the tyres and pressur is ok anyone any ideas thanks
would suggest that you have excessive play in either a n/s wheel or cv joint bearing, if there ok then check other steering joints and steering rack, for excess play!
N
nav
sorry but what is the n/s wheel it only does it in 1s gear when you floor it it just i only drive it once a month, daily driver is 1.4 golf is it poss it is torque just trying to gain traction
andrew
Try getting 4 wheel laser aligment done.
Mine was like that a bit right tow camber was out, all fine now.
