Just tried it, feels strange with a few pops and bangs 8) It's the second one down on the list which came set to 7500 when new. Not sure how long the manifold/turbo will last using it though.I've already been thinking of this. It is a pro and it will have launch control etc. My guess was the F/C options in the idle setup are where this is set. I have wound both these up to 7500rpm just in case.
It's not connected with the A/C switch but I think they were limited as to what it could be called as the same commander (415-N001) is used for some Scoobies/GTR's and other SR20DET's. That bit is still in Japanese as it was on a separate sheet so I don't have an electronic copy. The separate sheet has a little bit of english which says AC on and off for that option.
Big hint for anyone getting a PFC or PFC PRO before they start using the universal commander (415-X001) get one from Andy Forrest or other Scooby tuner/mapper my mate got one for ~ £80! How gutted was I!!!!
Not quite, I don't think the Blitz switch would have anything to do with the daughterboard. Follow the wire from the switch and see where they lead to. As long as the all the wires going from the loom to the ECU/PFC are all connected without going through some other piggy back unit then you should be fine. Are you using the normal boost control solinoid? Is the Blitz system still in use? Did the switch work on the previous ECU? Are there any other "extra" bitsPotentially a huge penny has just dropped here. My previous system has an ECU with an A/F modify piggy backed through a daughter board. The boost control was a Blitz E-SBC with a single switch selector for changing between standard, 1.2 and 1.5 Bar. I couldn't find the control unit and have had most of the dash a apart in the past but assumed it must have been very carefully hidden away. I think the PO has already done what you suggested (Nice idea 8) ) It has an an external boost gauge running from a tee already that replaces the standard. I'll have to have a good look at the wiring diagram for the car and see if I can't start tracing what's exactly going on. It would explain why swapping to the old ECU makes things better again.
No probs, I checked and thats what they were apart from the O2 which was sat at 0.01v after I pulled up but thats a separate issue.Thanks for confirming the readings.
LMAO :lol: well that'll do itmy wife got 8 ton of top soil delivered outside the garage on Wednesday. A fantastic security measure :lol:
