AJ4
Depending on how fast the AAC voltage is changing you probably wont read ten volts you'll only read an average voltage ( assuming your using a DC meter ). You really need an oscilloscope to check it properly. Your meter might only take a reading every second or so, and if the signal is rapidly switching between 0 and 10 volts 5 times a second you'll never see it properly on a voltmeter.
