Chiffs
Have taken the inlet manifold off today and tested the AAC valve and FICD valve.
Both working fine and giving the correct reading as per the manual.
Took the Air regulator off (page EF & EC 634 of manual)
Took it apart and there is a slide valve in it which is pulled shut by a spring and opened by a solinoid i guess.
Looks like the spring is a little old and is not capable of closing the valve.
Holding the valve shut
Holding it open
Question being would this cause a high idle. Easy fix being a new stronger spring.
Your thoughts, im thinking this may be the cause of a high idle?
Holding it open
