ported
gtir350
I was told that polishing is not the way to go these days, And its best to have a bit of a rougher finish after porting :?
Dave
Dave
you def got the rough bit right then :lol: :lol: :lol: :lol: :lol: :lol: :lol: .
rob
AJ4
Yep, mine is very smooth ( but not polished ) all the way to the injector inlet, and from then on still a bit rough into the cylinder ( still a lot smoother than cast though ). You could mirror it if you really really wanted up to the injectors but its probably not worth it, but it has to be a bit rough wherever there is fuel flowing.
turblio
Polishing and porting this has been a subject of debate for as long as I have owned cars mines had it done but hey once the carbons built up
whats the point in polishing? I would agree with matching and smoothing
ports etc that may help
gtir350
Yep,
If you mirror polish every part then your not goin to get the air and fuel mixed + Loose low end power
80 Grit should be the highest you go.,woof
Dave
pulstar rob
so does anyone think i've wasted my time then.
spent about 25 to 30 hours doing this
just got to get it skim and the valve ground back in. then i can paint and fit it
stokie1
have 80mm single throttle boddy on manifold is it worth smoothing
the inside of the manifold
ki_saj_ng
:shock: well if it isnt worth doing it, at least it looks nice even though u wont be able to see it :p :lol:
some effort gone into that tho mate!
thanks a lot ki_saj_ng.
i've got a few more hour then doing both of the manifolds.
hopfully it should make a big difference when it's finialy fitted.
Nad
Yeah it should be rough, or have cut outs after the injectors to cause turbulence to mix the air and fuel.
Will read that bit later u posted Kieron.
Nad
N
Norfy
done the internals on mine with 80 grit.
AJ4, you can remove the lumps inside on your upper plenum (from the 2 bolts for the vac hose and PAS hose fixing) without leaving any holes.
not the same on the middle plenum tho, ground mine down and had to have it welded :oops:
is smoother tho
Norfy
