Play in the o/s/f drive shaft into transfer box
pulsarmick
Hi all i need some help i have some lift in the o/s/f inner c.v joint where it goes in to the transfer box should that be there all help need would be greatful many thanxs pulsarmick p.s is the n/s/f wheel bearing easy to do and can it be adjusted .:thumbsup:
Wheel bearings can't be adjusted that I know of.
They are relatively easy, but you realy need a press to remove the bearing itself. (probably could be done without, but I wouldn't bother trying, having done it on a previous car)
Compare the CV joint to the other side. A little play I would expect after all these years, but if it's noticable, it may be time for a new cv joint.
pulsarmick
lift in o/s/f drive shaft in the transfer box
thanxs for the help i dont have play in the cv joint its where the cv joint goes in to the transfer box hope the bearings are not u/s:doh:
another sunny
both of my R,s have had the same play, only in the O/S each time, i presumed it was because of the extra length in the shaft?
pulsarmick
thanxs
thanxs for the help just glad the transfer box is not u/s :-D
