AS above..
if anyone has one.. or ill have to buy new from PAR ..
THIS ONE :
http://www.par-engineering.com/nissantirs.htm#nissangtird
GTIR Dog Change
The GTIR 1/2 dog gearset is made from EN36A case hardening alloy steel which is hardened and tempered through a special heat treatment process after the manufacturing stage and is a huge step up for the performance freaks who have screwed a lot more power out of their GTi-R engine. This gearset is suited for drag racing, circuit racing, rallying and hi performance use. If you like 'launching' your car off the line then this gearset will take all the punishment. The benefit of this 1/2 dog gearset is that the gears are wider than standard (to increase strength) with a larger tooth profile meaning that there is a lower number of teeth and each tooth is a lot thicker (to increase strength even more). Lightning fast gearchanges can be made without losing valuable time with this 1/2 dog gearset. This equates to the most power capable racing gearset available. The dog gears will be rated at around 650hp.
A 1/2 dog gearset is suited for people who want to launch off the line in anger while making lightning quick gearchanges from 1st to 2nd, just like a proper race car. A audible metallic 'clunk' might be heard when changing fast, but the engine will be a lot louder. With a little practice a GTi-R fitted with a 1/2 dog gearset will be no extra hassle being used as a regular street driven car. If you are serious about the horsepower output of your GTi-R, then this is the gearset to get. The dogs on this gearset were designed for maximum strength and durability, the end result is the biggest dogs that could possibly be made.
VERY INTERESTED IN ONE OF THESE !!!!!
i know its an expensive bit of kit, if anyone has one they are thinking of selling let me know, or ill just buy a new one......
Tom
THIS ONE :
GTIR Dog Change
Tom
