Outline of Wilwoodying Midilite Brake Pads
Fazz
Hi guys,
having a bit of a nitemare trying to get replacement pads for the car.
I can order from Rally Design but trying to get them sooner.
Local shops need outline of pad to see what else will fit.
I'm running th Wilwood 4 Pot Midilite Calipers.
Want to get Mintex 1144's but told they are probably different.
Might just order the Poly Q pad from Rally, but trying alternatives as want to get asap.
Anyone got an outline or know for sure if Mintex 1144's will fit?
Got a Pad number?
Thanks.
PaulB
Other than trying pads for sizes you cant do much else. I was told that mintex dont make a wilwood pad.
I got in contact with Wilwood in the states and they do more pad compounds than RalDes, who I think arent that helpful.
I looked into getting some Poly J`s, as they worked when cold, and had a great heat range.
You left ordering your brakes to the last minute then........................ ?? :lol:
Fazz
Yep - didn't realise they were so bad till i dropped it off to get other bits fitted....
I've seena thread or 2 where Mintex 1144's mentioned but can anyone confirm if they fit the Wilwood Caliper???
