johnny gtir
The brackets are very heavy, i would love to replace mine with alloy. Was the first thing i thought when i fitted my first engine.
I dont think the Difference in Aluminium would make any Difference. I know copper and Ally should not meet (they react with each other) but alloy of Different grade is ok.I thought the group N manual (or what ever it is) just says to bin most of those heavy brackets rather than replace them with aluminium.
There may be a galvanic corrosion issue to consider with two dissimilar metals attached to a block which is also an electrical earth.
trip, is'nt doing the above to such a large degree (changing the castor) afecting the bumpsteer and or ackermann angle?
Hahahahaha - It's like you read my mind!!!!!wheel chocks to stop my exspensive Nissan storage cabinet from rolling of my mate drive
I can make you an Alloy housing thats easy. Take a Pipe 80mm then the flange and Weld it together. make the hole for the sensor. stick it in then seal it and job done 200£ and its all yours But what's the advantage?
