oil temp gauge fitting ?
As there is a standard gauge, you could probably replace its' sender (assuming the same thread) and the gauge with your new one.
You would probably need the sandwhich plate if there's nowhere to fit the sender for your new gauge without it.
Godzilla
ok will check if its the same size as iv fitted the gauge along with my volts one in the a pillar so both work lighting up but just obviously need the sender part working on it,
does anyone know the size of the standard sender of the top of there head without me having to get the car in the garage to be done
