JU5TY
Which pipe goes where on the below oil separator. I assume C goes back to the sump. Just don’t know about A and B, which one goes to the outlet on the cam covers and which one goes to the inlet pipe/filter?
Also does it matter if pipe C has a steep increasing gradient before it meets the pipe at the front of the engine where it drains down to the sump? I assume it does seeing as it will only drain out of the separator?
Will there even be that much oil, is it maybe worth using a catch tank over a seperator and blocking off the return to the sump at the front of the engine?
