Oil Pressure Sender location?
PrimeraRacer
ello all.
I'm fitting an Oil Pressure guage to my motor and I was wondering what the best location for the sender unit would be?
is there a place I can screw it into the block or should I tap it into one of the oil lines with a T piece?
Thanks in advance!
Kev
The oil pressure and temperature sensors are on the filter housing. The pressure switch is the big one. :wink:
PrimeraRacer
thanks for that I'll have a look at it.
I'm wondering if I can tap into the stock one or if I'm gonna have to replace it with this one!
You might be able to tee in your new one if there's room. I haven't looked in that area much to be honest :wink:
Mr GTiR
in an R it a bitch to get to as there's several brackets in the way. Not too sure if you will have more room in a prim ?
If you need a spare one, i have the full assembly in my shed if you want it?
E
Edd
Its piss easy to get to the oil pressure sender unit :lol:
if your lucky the thread of your new sensor might be same as std thread :wink:
