O2 Sensor wanted A.S.A.P. !!!!
RO_SUNNY
Hi guys / gals.
I really need this one A.S.A.P.
I need a brand new one or with small usage ( I already have 3 used one that are not working due to several reasons :(((( )
Thanks,
B
RO_SUNNY
Hi Dan,
Thank you very much for the usefull stuff!!!!!
The 1'st link I have tryed but the guys from there told me that they don't ship to Romania (my country)
Will the skinny 12mm will work on our cars????
Thanks
danr
yes it will (must be for RED top, BLACK top is Zirconia; no good), its a titania red/blk/wht wire sensor for the silvia sr20det, canadagtir ausgtir etc all use them :_)
failing that, contact bosch or ntk (who nissan use) direct and tell them you want a 3 wire titania with 12mm thread, probably cheaper than buying a stock part. then you can splice it onto one of the many connectors you must have! lol
danr
Therefore this is the sensor which I need and can be used on our engines!
http://cgi.ebay.co.uk/Nissan-OEM-O2...t=Motors_Automotive_Tools&hash=item588a78c3f2
yes
I used a reducer very similar to that but after fitting copper washers between the boss and reducer/reducer and sensor the tip of the sensor didnt stick out far enough and the car ran like crap.
hmm, i thought this might affect mine too. the tip just stuck out. but it has gills and the pressure of the gasses should blow into them. i used rtv sealant instead of washers, so far so good. the lambda reads between 0.3/0.9 at idle, so okay... atm :_)
but, the pipe should have a reducer in there already. its just a bitch to get out.
