mynheers_a_pint
nope nothing at all.I had an issue once were the plug that connects to the loom was slightly damaged and had worked loose and so was cranking over but not obviously starting. This maybe an issue if you have recently been fiddling around this area i.e. around the re-circ valve area or dv area if you have replaced it.
Other than this, as suggested check the ignition side of things, rotor, dizzy, leads, loom.
I know you say you can smell fuel but it may be worthwhile just double checking that fuel is actually being pumped just in order to check this off the list.
Have you changed or carried out any work on the car recently?
Ant.
