Non starting
Boooooost
Finally got my R ready to start and guess what? no go lol. Turns over fine so took out plugs and found them dry so no fuel. Took feed pipe off fuel rail and theres fuel there at pressure. Checked for spark no spark. I also noticed that the rev counter isnt moving, the only thing I can think of is that the ecu isnt getting an engine speed signal. Where does this signal come from?
Cheers Matt
AJ4
... the engine ? :roll: :lol: :lol: :lol:
Seriously though, IIRC it gets a signal from the crank angle sensor ( inside the dizzy ) and needs that cranking signal before the ecu will switch on and do its thing. Check and make sure the plug is connected...
If it is, measure on the signal pin and turn the engine over, you should see the signal jumping up and down as you crank ( can't remember if its 5v or 12v, but you should see it switching ).
Dooie Pop Pop
Uncle Winnet said:
the dizzy and revese plugs sound as if they are the wrong way round
its an easy mistake to make
john
:roll: LOL :lol: :lol: :lol: aint that freeky, two in one day :!: :lol:
Mr GTiR
john
like i said it's a common mistake to make. You not the first Stu and you deffo won't be the last.
Dooie Pop Pop
neil240z said:
just shows you 20 quid is priceless when you get people solving your probelms!
you are sooooooooo right there Neil :lol:
Boooooost said:
Lol feel like a right tool it was the plugs :oops: Cheers guys
Matt
dont tell me it took you 11 days to figure it out :shock: :wink: :lol:
