johnsy
id challenge them to prove how loud a stock item isthey said its that level, or the fact it produces significantly more noise than the standard system
we cant even find the db levelof the standard exhaust, what makes you think plod knows better,And then when they do and your oppurtunity to take the fine is gone you have a nice day in court.Which you will probably lose.
If I could fit another silencer into my mongoose without killing performance I'd have one for definite.
The exhaust must record a decibel level not exceeding 101 db(A)
This level will be recorded at the height of the exhaust or 200mm from ground level which ever is greater, placed 500mm away from the exhaust outlet at a 45 degree angle to said outlet.
The engine will be run at a speed between two thirds and three quarters of it’s maximum to achieve the recording.
I don't see the point in drawing their attention.These cars aren't exactly subtle and if you piss off the local plod they will be pulling you for allsorts.Plus with those silly new ASBO laws they can manipulate them to their advantage.If they decide you are casuing a nuisance, which excessive noise could be classed as they can issue a warning and if you don't sort it, seize the car.My thinking is, why be a smartarse and provoke them?we cant even find the db levelof the standard exhaust, what makes you think plod knows better,
i challenged the fookers over my plates, they said the lettering was under size, i argued it had a valid m,o,t, outcome was i escaped a fine but hadto get a m.o.t center to stamp the ticket they gave me,
the fool who wrote the ticket out was all like nice car dont see many of them often, later on when i was looking at the ticket he put it down as a toyota ,and that was the taffic filth
This is exactly what happenedFound this. I bet they checked Keastygtir's on C weighting to get a fine.
Your right there is no point in arguing, you just need to be confident, know what you are talking about and when it comes to questions understand what they are asking you and have a plauable answer for them.I had my plates checked, the size of the lettering was the minimum, but then they said I had to change the front plate had the sapcing 1mm to small.
Pointless arguing and just told to change it!! That was by a traffic cop, which I have always found to be more ok than the usual plod who are normally just jealous we have better cars than their shitty diesel astras or whatever crap they drive!!
I think Andys spot on with what he's said.Your right there is no point in arguing, you just need to be confident, know what you are talking about and when it comes to questions understand what they are asking you and have a plauable answer for them.
Import cars are exempt for front uk registration plates reg.
Mine does not conform, but it can be read from 25mts away and its ANPR detectable.
I've dealt with the traffic division when it comes to having a stop check.
Just make sure you know what you are talking about, be confident and polite and 99.9% of the time you'll come out on top because of the technicality.
However they could well just give you a VDR (vehicle defect report) for something else that's wrong with your car.
I'm just polite, courteous but confident. They see that they'll pick up on it and it pays off. ;-)
