Dangerous Dave
there was alot of play before i took the hub nut off then when i took it of it fell out of the cv joint!?!
sorry am a little thick when it comes to wrighting and spelling!If your write clearly we could understand you easier and be more help. I have the opposite problem to this. My car wont let me put it in gear. Thought it was slave, got a new slave and bled the system. Same problem. Ordered new master so see if that fixes mine. Sorry about thread jacking.
If it's not goin in gear, and u can see when you press the clutch that the fork IS being pushed back and forth with the slave cylinder, then the problem is not in the master/slave cylinder.. it will be clutch/gearbox problem.
