New shocks and springs
boucherie
I've discovered that the offside front of my R is about half an inch lower than the nearside, and as a result the tyre has been catching the arch slightly. What are the best options in fitting new shocks and springs or should i fit springs first and see how it goes?
You could probably swap both front springs and see if the problem swap over with them. It may just be the weight on that side is more, or you may have a broken spring, or even a dodgy damper.
