Dooie Pop Pop
my next brake problem.. fixed
:doh: getting sick of this:-D
fitted my reconned rear calipers and bled the brakes (properly, several times..well about 18 pumps a corner in the end ) and my brakes are still crap.
my abs light is on and the abs ecu is giving me a code 6 front right. i think this is crap in the teeth or sensor from where a gator split a while ago...im gonna pull the hub of tomorrow and clean it out.
what i need to know is:-D
where is the fuse to disable the abs? there' s two on the passenger wing do i just pull those two and its off?
would having an abs fault cause my brakes to be really lame? its like there' s grease on the disks the cars just not stopping properly, i cant even brake hard enough at 30 to jerk to a stop!
there' s definitely NO air in the system too BTW :frusty:
cheers Stu
cheers Stu
