Fast Guy said:They'll do for now, but don't expect miracles.
(It's the same set up I have)
I have worked mine hard on a few occasions and i have to say i got no fade at all!gtirx2 said:Do you guys like the 1144s?I only ask as i am using them with cheap ebc grooved and dimpiled discs and i hate them.One good stop from 100ish and then there done till you let them cool down again.
Not much better than the standard set up imo,really wish i had gone for the 1155.
You may not have bedded them in properly ?!gtirx2 said:Do you guys like the 1144s?I only ask as i am using them with cheap ebc grooved and dimpiled discs and i hate them.One good stop from 100ish and then there done till you let them cool down again.
It's not the amount of miles on the pads that defines when they're bedded in, it's how they're actually bedded in.gtirx2 said:I see what you guys are saying,i had the same conversation on the mods site and other people seem to like them too.It must just be me,they have done a good few 1000 miles now so i think they are bedded in.
I seem to stop from high speeds once or maybe twice then when they are toast they make a rubbing/grating noise until they cool down!
1155 for me next i think.
It's not shuddering, it's groaning. Do you ever read posts properly ???? :lol:jpward said:Only thing i noticed was a little bit more squeel even with a bit of copper slip on the shims but no shuddering!!
Are you sure its not related to disc warp as my old RST used to warp noticable under heavy braking?
I know what makes brakes squeal thats why i use a dab of copper slip and kept the shimsyoungsyp said:Squeal is caused by the pad vibrating in the caliper or excess brake dust on the pad and caliper assembly !
My symptoms seem slightly different to 'gtirx2's' as, my brakes work as normal when the groan
Nope, that would be paaaaarrrrrrrrppppppppping !! :lol:jpward said:The groaning is probably yourself Paul when your in pretend WRC mode
I think I kind of know the type of noise you are talking about now my Bike runs small twin 310mm discs and makes a funny noise under heavy braking but it has drilled discs using sintered pads but i was told thats normal on a bike wonder if it is pad material and I have just not been as hard on the anchors in the R as you guys? :?youngsyp said:Nope, that would be paaaaarrrrrrrrppppppppping !! :lol:
Seriously though, I might try and 'drive through' it and see what happens. It could be high spots on the disc where the pads aren't getting used as they were designed for. If it is this, the sustained heavy braking might smooth the disc surface off ?!
Anythings worth a try !!
Yep, mine has cross drilled discs too which, again, are expected to groan as a matter of course !!jpward said:I think I kind of know the type of noise you are talking about now my Bike runs small twin 310mm discs and makes a funny noise under heavy braking but it has drilled discs using sintered pads but i was told thats normal on a bike wonder if it is pad material and I have just not been as hard on the anchors in the R as you guys? :?
