Well, I have a 3" exhaust, including elbow, up to just before the decat, where it tapers down to 2.5", with lagged downpipe. A Blitz SUS intake kit, port matched and lagged turbo to intercooler pipe, mildly ported TMIC inlet and outlet pipes, all OE breather and carbon canister parts removed. OE fuel pump with full battery voltage (re-wired) and reinforced grounding on major parts under the bonnet, including MAF and TPS. With my Apexi AVCR set to 1.15 kg/cm. The car just made 318 bhp and 290-295 lb's/ft of torque. The car is running very lean under load and it would seem, is operating outside the fuel and ignition maps at these times, when Conzult is connected up.jameswrx2 said:Interested in what you mean?
I know the std unit can now be remapped, just wondered what the limiting factor is?
Yeah, what I meant was.. Why buy the Mines if you can just custom MAP the standard ECU to match your mods perfectly and make the most of them. A generic MAP is never going to be as good I'd guess.youngsyp said:Not sure if that answers your question on not ?!
Thanks Bob, that would be idea.pulsarboby said:paul you dont need a daughter board fitted to map the standard ecu!
if your after a mines, i may possibly have one in shortly, mattytappy just bought the last one off me.
had 3 mines units in within the last 2 months. they really do make a lot of difference to the performance of the car, its quite an aggressive map at 1.2 and the throttle response is much more crisp, they also seem to eliminate any bogging down periods throughout the rev range.
i drove the car of the first one i fitted before and after and was very impressed by the difference it made.
once mattytappy has recieved and fitted his one im sure he will post up the difference it makes to his car.
The simple answer is cost !jameswrx2 said:Yeah, what I meant was.. Why buy the Mines if you can just custom MAP the standard ECU to match your mods perfectly and make the most of them. A generic MAP is never going to be as good I'd guess.
I thought you were saying the std ecu was limited.
Chris Gardner said:Quick question on a mines people, how does it work with regard to a boost controller?? IE I have a profec b spec 2 in my R and if I bought a straight swap ecu like the mines would it override the boost controller?? silly question but just need to weigh stuff up!!
Im sure you do bob. If you open up a mines ECU, youl see a daughterboard already in place. The chip inside a GTiR ECU cannot be reflashed, and needs a daughterboard fitted, along with a jumper moved on the PCB.pulsarboby said:paul you dont need a daughter board fitted to map the standard ecu!
PaulB said:Im sure you do bob. If you open up a mines ECU, youl see a daughterboard already in place. The chip inside a GTiR ECU cannot be reflashed, and needs a daughterboard fitted, along with a jumper moved on the PCB.
Interesting Bob, keep us posted !pulsarboby said:will have to come back to you on this one though as im only going by what im told, and im certainly no ecu expert:lol: but will have a definate answer very shortly;-)
That was an area I had considered Jim and, could still be on the cars. I'll just have to see what sort of price, a Mines ecu comes in at !campbellju said:AFC and a WB lambda. You can check the fueling and tweak it yourself.
Just an alternative option for you.
Jim
