George, I know that theoretically its a very nice idea but I don't entirely buy into everything you read about. Mainly because its taking a purely thermodynamic view of what is an aerodynamic system. I'm not going to explain this well, but my take on it is that the water/meth solution isn't going to change the aerodynamic characteristic of the impeller, there will always be the same loss mechanisms (e.g. separation, recirculation) and most importantly there will always be shocks generated which will lead to the onset of choke. As I'm sure you've read injecting water/meth theorectically absorbs the energy generated through these loss mechanisms through phase change making the compressor more efficient (or more adiabatic if you want to sound clever :lol
. However in normal operation (near the middle of the map) order to be truely adiabtic the amount of water/meth will need to perfect for the level of losses, which lets face it isn't going to happen. Then if we look at the idea of acting like a bigger compressor, yes the efficiency island in the centre of teh map will be bigger and hence cover higher flows, but the onset of choke is predomenantly caused by the shocks generated by transition to supersonic flows and injecting water isn't going to change this. This also doesn't take into account the effect of changing the air density into the compressor inlet will have on the surge line (I love how this gets over looked by the pre-compressor fan boys), basically your surge line is going to move to the right making it more likely that you will run into surge.
So in summary the best you can hope for is to make the compressor a bit more efficient and have a lower inlet temperatures. This can just as easily be achieved by post intercooler injection to further increase the charge cooling efficiency and by running a decent amount can have further anti-knock characteristics by under going phase change within the combustion chamber. With the added benefit of not risking damage to the compressor impeller.
