Manifold studs
memski
Does anyone know the exact specs of the stock mani studs? I'm sure they are M10, but I'm not sure on the thread pitch, 1.5 has been quoted already but I want to check to be doubly sure.
Also does anyone know where you can get longer studs from (and possibly stronger) over the net?
Cheers.
AndrewD
Cheers.
try unbrako bolts, they are in lamens terms, strength hardened, and from previous occassions ive gone through 5 drill bits to get a pilot hole into em bastards, they are the shit
just search unbrako
Mr Overboooost
the manifold head studs have a thread pitch of 1.25 and not the usual 1.5mm.
hope this helps
cheers
gary
memski
Right, tried Rally designs and they won't supply unless it's for their own manifold :roll:
Length is 4.7cm, I'm going for 5.7cm. Have got a local machiner on the case, and also Hizo motorsport (who I highly recommend :wink: ).
Will let you know how I get on.
Mr Overboooost
what i did was went and bout some high tensile bolts from a local screw supplier.
then i cut the heads off on a lathe and hay presto some nice long head studs :D
cheers
gary :)
