Anyone had any thoughts on this blow through set up using a Z32 MAF.
From that pic, I take it your still using 2.5" intercooler pipework. I was going to convert all the pipework after the cooler and up to the plenum into 3" and chop the end of the plenum off and convert that to 3" as well.Dan_GTiR said:I am going to use a Z32 MAF in blow through Steve.
I was speaking to Tony over on Modifiers a while ago, he used a standard MAF in blow through, and I told him that I was going to do it with a Z32, he told me that I should go for it, as he had good results, even though he was still using standard MAF.
http://img.photobucket.com/albums/v739/danstorey/IMAG0086.jpg
The link, is the billet aluminium Z32 flange I machined at my old job, that will be welded into the intercooler pipe, for the blow through setup.
I think there is a few people on SR20Forum using the Z32 MAF in blow through, I'm sure if you do a search you'll be able to find something on there.
Hope this helps.
Dan.
IMO you don't need 3" IC pipes. unless you're running silly amounts of boost.stevepudney said:From that pic, I take it your still using 2.5" intercooler pipework. I was going to convert all the pipework after the cooler and up to the plenum into 3" and chop the end of the plenum off and convert that to 3" as well.
Steve
mine is 90mm ( 3.5 inches ) :lol::lol:Dan_GTiR said:2.5" should be fine for nearly everybodies needs
D-Fens said:mine is 90mm ( 3.5 inches ) :lol::lol:
Is there such a thing ?D-Fens said:The only thing I'd be worried about is using a designed for draw through MAF as a blow through. Its designed to work in vacuum, its not designed to work under pressure, how do you know its not going to blow apart ? :lol: I think I'd use one specifically designed for blow through.
