No you don'tDeffo looks like a vacuum problem I get a good -50psi @idle I think. Do you have all the black condoms over the throttle ports?
i had no vacuum coming from any vacuum lines, boost/vacuum gauges were reading next to nothing...Bevis, if you have nearly no brakes then that's a clue. Check your vac line from the brake servo to the inlet manifold. If your car idles at all you have vacuum. If your over fuelling then your ECU is reading too much load. (airflow) Your next option would be to get nissan datascan and see what kind of values your seeing on your sensors.
