Just Fitted A Engine, And It Wont Start
serks2
Just Fitted A Engine, And It Wont Start please help
Hi
i just got my engine ftted in to my R yesterday, and we cant get it to start!! i used a battery charger and jump leads and it still never worked, we even used easy start spray!! does anybody have any ideas of what it could be or can anyone tell me what i have to do to get it started.
cheers
turbodaily
have you checked you are getting a spark first of all???
go around the engine and double check all the plugs etc are all connected up.
so is it just cranking over or what?????
turbodaily
hmmm pull them out a if theyre wet, blow torch them and whack them back in,try starting it whilst theyre still hot.....
serks2
ok mate il try my best!! im really worried that the engine might be bad!!:?
Try swapping over the reverse switch plug and the dizzy resister one matey, They are the only two plugs on the engine loom that are the same fitment, It's been done plenty of times before so that may be your problem.
jpward
Does that mean she will start in reverse :lol:
serks2
we done that already mate that was the first problem we had because the sockets look the same thats sorted now!! we have got spark and we've got fuel but it still wont start,,
Any more suggestions i could try tonight??
Thanks again evryone!
Have you checked the timing ?, I can't really understand why it wont at least try to start if your getting fuel and a spark :? .
Maybe you've just flooded it badly, Has the dizzy meen moved ?.
serks2
it does try to start, it just keeps cranking over!! but just wont fire up!! the dizzy is still the same!! do you rekon it could be the timeing??
serks2
just checked it again and the sparks are wet!! maybe thats why!! does anyone know why it keeps flooding??
serks2
turbodaily said:
have you cleaned them up and tried again???
Yeah tried that too,
I even tried and changed the air flow meter!! but it still wont start!!!
I thinking that it might be a elictical fault!! maybe the immoberliser or something!!!
any ideas??:? :? :? :? :? :? :? :? :? :?
hmmm
Checked all the fuses inside by the drivers footwell? One of them is ST Signal or something. Could be blown? Worth a look.
