jgy 240sx clutch
Rishi
Still waiting on some shims!
Just make sure that its for an SR20DET and you will be fine.
Rob uses one in his.
Its the flywheels that are slightly different because they use smaller bolt holes which are easily machined! ;-) But you will be using your current flywheel so its ok.
Rishi
andrew
it will not fit so do not do it
check the daimeter too
215mm is sr20de
245mm gti-r
i beleive the 200sx range is is 225mm
and also ask is it for rwd, fwd, 4x4 it does make a difference even if it is the same diameter
Rishi
215mm is sr20de
245mm gti-r
My twin plate clutch is 184mm.
You can use S14/S15 200SX SR20DET Clutches with the GTiR... FACT!.. All the RPS clutches are the same for GTiR and 200SX. Same for Exedy, HKS, etc. Its just the flywheel thats slightly different.
Just ask Jason @ JGY for a clutch that will work for the GTiR and he'll sort it for you.
Rishi
