C
Cadiz
DOH!! I need help!! I think I've had the dreaded "clutch bracket failure" happen to my 'R. When I got in the car this morning I found that the clutch pedal had lost a load of pressure and there was a load of fluid on the clutch pedal and floormat. On the way to the garage the clutch gave up and I had to get a tow the rest of the way ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The mechanics haven't taken a look yet by my current theory is that the "clutch bracket failure" problem has caused the master cylinder to crack and cause the fluid to leak out.
If this is indeed the case then...
1) Will the bracket replacement manufactured by StevePudney (linkage) work as a good replacement if the clutch pedal has broken off??
2) If only the clutch pedal and master cylinder are affected does the engine have to be dropped in order to replace the parts?? I want to make sure the mechanics don't spend hours doing this and charge me a load for labour when it's not necessary.
3) Can the master cylinder be replaced easily without having to replace the entire clutch. I assume that the cylinder is kept separate from the main body of the clutch.
As you may have noticed from my questions I am not a mechanic so please be gentle with any answers!!![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
