be very carefull before you fit this clutch with a different release bearing!
when you have the old one off, lay the pressure plate flat on a bench and measure from bench top to outer spring clearance (centre hole edge), then do the same with the other clutch and make sure there the same.
the reason i say this is because some pressure plates are a different depth and require the release bearing to be fitted as a 3 part kit! if you do not fit the release bearing with other clutch parts then you may have a problem engaging a gear as the release bearing will not fully dis-engage the drive plate.
chances are that it will be ok but it doesnt take 2 minutes to check before fitting it back;-)
if clearances are the same then a stock nissan release bearing will be more than adequate for the job (it is afterall just a bearing that spins)
