Its not got a mongoose on it does it?gtirneil said:Just bin out in the car its idling at 1350 rpm but is also popping slightly :?
Paz
At thenmoment just a 3.5" goose backbox but full system from turbo back is on its waypaz said:Its not got a mongoose on it does it?gtirneil said:Just bin out in the car its idling at 1350 rpm but is also popping slightly :?
Paz
Plenty of money paz my boy :lol:paz said:You can possibly tell by the clutch feel, but mines standard and feels heavier than the last R I sat in with an uprated clutch. If you have the money to change it as soon as it slips that ok.
I suppose I'd have to hear the idle to see if it sounds like mine fella :?
Paz
Not keepin at 1 bar its going to be standard most of the time as that is plenty for mepaz said:You're going upto a bar though aren't you (guessing by the boost controller etc)? If so and its standard and reasonably old, it'll probably slip eventually.
Don't think I'll be down Bolton, not been into that since the R really, but might go and check out the new place to catch up with a few people.
Paz
thats what i said.... 8)AJ4 said:...or the accelerator pedal / cable is adjusted wrong...![]()
if anything ti is 2 slack not to tight so its pulling, its going to hiteq in a week so iull get them to have a lookbex said:thats what i said.... 8)AJ4 said:...or the accelerator pedal / cable is adjusted wrong...![]()
yer it got to the point im gonna i replace all the hoses n maf to see if that will cure the problemAJ4 said:lol, lazy bottom, just pop outside and have a look yourself
Seriously, there is about 15 different things that cause fast / uneven idle on a Pulsar, good luck finding itMost people just live with it :shock:
Haha i try not to get me hands dirty lol, i can live with it, it doesnt bother me just dont want me R' blowing up after 1 dayAJ4 said:lol, lazy bottom, just pop outside and have a look yourself
You mean a straight bit of pipe then :?: The mongoose dosent have a backbox, it just comes over the rear subframe and straight out the backgtirneil said:At thenmoment just a 3.5" goose backbox but full system from turbo back is on its way
Sounds like an air leak to me, mine was doing the same thing the other day when i forgot tp block off the pipe that used to go to the dumpvalve.gtirneil said:It pops on gear changing buit seems a bit lumpy at idle
because you can't drive for shit?gtirneil said:I took the IC off tonight and noticed that 1 of the 4 blanking plugs were missing so i found something to block it and now the idle has dropped to 950 yey
Bad news is now it runs like a sack of Skoda and hesitates when accelerating, anybody know why that is?![]()
