PaddyPower
Can someone tell me how often the following should be changed (if at all)
I apreciate it is not as important to the running of the car as the engine oild, but does it degrade etc?
1)Power steering fluid.
2)Clutch fluid
3)Brake fluid.
Also how much fluid is required to fill from empty each of the above.
Going to drain my clutch as it seems to have an air block in it and might aswell renew fluid aswell as bleed. What is the best way to remove all the old fluid? Will just pumping the pedal do the trick? :roll:
2)Clutch fluid
3)Brake fluid.
