how to contact hi-spec for brake kits?
str_motorsport
i would like to contact hi spec big brakes for a brake conversion for the pulsar and possibly ask them if they are intrested in a group buy, but they e-mail sddress is not working...
any other address that works?
thanks
David
str_motorsport
i will call them even if it was better to get in touch by email for me...
what do you think about the 335x32 with 6 pot conversion?and the 300mm rear kit?
which are the best pads to use?
stokie1
same set-up as mine
back end can get abit twitchy if u brake violently
the red stuff pads up front r good and last a long time and r quite
str_motorsport
hi mate, do you have any pic of your front brakes?
what about the yellow stuff pads?
so what do you think of them?
good improvement over std brakes?
do you have 17" whells?hope they will fit under my tecnomagnesio tm sport wheels....
stokie1
the difference over standard brakes is a major shock :shock:
they will fit under some 17" wheels but it is tight
only down side is the weight, have noticed slower acceleration and reduced top end over standard setup :cry:
str_motorsport
according to hi-spec web site a 335mm conversion need 385mm wheel internal diameter.my wheel are 391 so they should be ok!
will try to contact them...
so anyone intrested in the rear conversion???
