Ok just need to confirm the process of changing brake pads please. Might get the names of the parts wrong though...
Remove wheel . remove the 2 screws that hold the caliper in place, then remove it. Slide out the old pads. Then put some copper grease on the back of the new pads and slide them in. Push the pistons back in and put the caliper back on and screw closed. Then bleed the brakes.
Correct? and how should i push the pisons back in. Would some large pliers do or will that damage them?
thanks
thanks
