How much Voltage produce the Maf from RB25DET????
Thor
Hi,
can anybody help me? my R do not run with the Maf from the RB25DET. The voltage that produce is to high i mean. Can anybody tell me how much it must´produce at 1500, 2000 and 3000 RPM? I have fit the Apexi PowerFC and it must be run with them.
Sascha
GINGA
Have you setup the power fc to work with the new maf and presuming you have new injectors are they setup correctly also :?:
Think the voltage on idle is around the 1 volt mark with the z32 maf.
Thor
Yes i have! The injectors in the moment not right work. I have the Sard 660cc in it and they will not really run.. Which is the best Maf? From RB25DET, VG30DET or wich??
