HKS 2835 TURBO
stevepudney
GTiROC CHAIRMAN
ANYONE WITH A HKS 2835 TURBO.
ARE YOU HAPPY WITH IT, WHAT SIZE INLET IS ON THE TURBO 3" OR 4" AND WHAT SPEC AND BOOST IS YOUR CAR RUNNING
GINGA
Lex has the Garrett version of the gt2835r and his seems to go ok :shock: if you go for the one with the 4" inlet (2835r iirc) then it is not a direct fit on the standard manifold as the inlet will hit the block and you'll have to either space the manifold out or cut the flange off and reweld it on at a slight angle which will also mean you'll have to modify the downpipe to, might be best to give Ian at Hiteq a ring about it as he did Lex's for him :wink:
