nismo-400R
why am i getting mayo in one of the pipe on my forge oil catch can?
That's about the right temperaturenismo-400R said:aslo my fan doesn't start till it gets to 90-95c
mine have all ways kicked in at around 90/94c with an after market gauge, but i will read the manual to see what it says? The ga engine fans come on at 82-88c th sr engine gives no temperature so it could be as you say it looks like i may have to move my after market sensor to the return pipe.nismo-400R said:are you sure mate?because it used to kick in at 80-85c before i had this oil temp problem
They should kick in at around 95-96 degrees C.nismo-400R said:aslo my fan doesnt start till it gets to 90-95c
It's linked but, only in the very loosest sense...nismo-400R said:anyone?
I'd say it's more likely that the gauge sensor is flaky. The oil pressure and oil temp gauges are known to be very.......... variable on the GTiRs and I certainly wouldn't use that as a measure of what your water temperature is doing.nismo-400R said:kind of does,but like my fan doesnt start to work till it gets to 90-95c on the oil temp gauge,where as before they started at 80-85c on the oil temp gauge and thats with my 16row front mount oil cooler,could it be my cooler sandwhich plate thermostat not working?its bin on there for around 3years now
