High Idle
turblio
Hi all
Right this high idle effing problem came back to mine again and I
thought ok, I AM gonna beat you so have just spent nearly 4 hours
unbolting sealing fondling and god knows what else and then ...
pushed down on the maf plug hard... normal idle! so after 3 years I think
I have found the real culprit (DV leaked once which caused it for a while) :D :D
Frank
memski
Frank, sorted out my idle problem today and it was the maf, but now it idles at 1500 lol. Will push that bugger in :twisted:
J-GTi-R
Was trying to sort mine for ages too (even took it to Hiteq), but only recently notices the pipe running to the boost gauge sensor was split, letting air in. I cut off the end and stuck it back on and voila, 1000rpm idle...
T
T11EWL
They're the sort of problem you don't mind getting :lol:
Wonder how long / how much Nissan would charge for the same diagnosis ?
LeeSmith
Where is this pipe m8???
J-GTi-R
It runs into the fuel pressure regulator on the end of the fuel rail (from memory). on the right side of the engine at the top. I'll try and e-mail you a pic if you can't find it.
