Matt Evans
I've noticed that for a while now, my gear change has been a bit off. Then over the last two days or so it got really bad. I had to push the clutch pedal right to the floor and when I tried to select a gear, the stick would just stay there for a second or so and then finally engage.
I adjusted my clutch pedal and bled the system with new fluid only to discover that I could no longer select any gears at all! I re-adjusted the clutch pedal (got it down to a tee now!) and once more bled the system, to then find that the slave cylinder piston was being pushed right the way out when the clutch pedal was pressed, but not returning when the pedal was released, plus the Clutch return lever (I think thats what its called - the bit that the slave piston pushes) was twisted.
Is this lever supposed to have a certain amount of twisting movement in it? Or is it broken and thats why I can't select gears?
