willgbr
I dont think there are many places that can do it properly full stop are they?
phew.
they really fecked up fitting mine :twisted::evil::evil::evil:
phew.
i will get some piccy's for you stu as it was a work of toilet your old block:evil:phew.
we shall see.8)I dont think there are many places that can do it properly full stop are they?
fairdoos, thought you were a screamerpipe wannabe :lol:
I just thought I would share this with you. http://www.fs.isy.liu.se/~larer/Projects/main.htmlbut if it was up to me i'd be going for as high a comp ratio i can get.
Running a big spec stumo with E85 fuel setup
I've not read the link yet but it's really a suck-it-and-see, even if you've got all the equipment.I just thought I would share this with you. http://www.fs.isy.liu.se/~larer/Projects/main.html
This research is not new and is backed up by other similar areas of research, but in essence, in order to determine the best compression ratio for an engine research must be undertaken to establish the point of PPP (peak pressure position) vs compression ratio/vs fuel to be used.
For an engine to develop the best amount of torque and therefore power under all operating conditions PPP occurs at about 17deg ATC. However the ignition advance to achieve this can vary greatly depending on engine load/rpm etc (hence why we used 3d ignition maps).
Problems can occur when the compression ratio is such that firing the ignition at an optimal point to create PPP @ 17deg ATC causes the fuel to spontaneously ignite, forcing you to have to retard ignition and as a result loose efficiency and power, it is at this point that CR needs to be dropped. Conversely you may find that you are able to up the compression ratio to optimise the engine design for a given spec to enable more power from it if 17deg ATC is easily achieved without approaching upon knock.
Ed
Me too - I want to know how much of the problems people predict are just scaremongering, and how much is truth. Have you done anything special to run it on E85? I'm unsure about what is and isn't compatible with a polar fuel instead of a non-polar one; what fuel pump are you using (I'd read that it needs to be different because ethanol is conductive whereas petrol isn't).Let us know how you get on, I'm interested to know what is needed to use this effectively on an R.
