willgbr
Hey guys just looking for some advice basically this is what the problem is.
"Message from AGRA - Hi, we’ve just checked your compression ratio and it was 8.7:1 which is higher than we like to set it.
We usually set them between 8:1 and 8.5:1. The only way we can lower it (without machining the piston crowns) is to fit a thicker head gasket. I have a 5 layer Cometic in stock that is thick enough to take comp ratio down to 8.3:1. The 5 layer gaskets are better for high boost applications anyway. I can either offer you a straight swap for your existing head gasket or you can buy it from us?"
I have read some things about cometic headgaskets, dont know whether to take it as gospel or not. Looking to hear from some ppl in the know.
Thanks
Will
Thanks
Will
