GINGA said:you need a head gasket as close to the bore size as possible so 87mm in your case (other wise it can fcuk your head and block )
Not so any small gap(especially one with sharp edges.) where air fuel mix can get trapped leaves the possiblity of det especially on high boosted engines.vpulsar said:GINGA said:you need a head gasket as close to the bore size as possible so 87mm in your case (other wise it can fcuk your head and block )
BUT ONLY IF YOU LEAVE OUT THE DOWL'S :roll: :roll: .
rob
GINGA said:"looks for the sticking 2 fingers up at Rob smiley" :lol:
