GTR R32 brakes ?
C
Cashpoint
To fit both caliper and disks will be very expensive as you will have to do major work to the hubs as the r32 GTR is a five stud pattern for the wheel and the R is a 4 stud. You would need 16 or 17" wheels anyway depending on the clearance. Then on top of this you will need to have a bracket fabricated to fit the calipers onto the hubs. Few years back Hi-tech or Abbey did a similar conversation cost around £1000 + fitting. Your better off trying to get hold of a set of caliper from a 200sx and then getting the bracket made up.
GTR stock brakes:
16" vent 4 pistons forw
14" 2 pistons back
men says 300zx brakes will be good ?
kyepan
tbh it would be cheeper to get a set of willwoods from the group buy. they are 4 pot light weight calipers.
C
Cashpoint
There no point puttin the 300zx brakes on as the R's brake system isn't designed to make full use of the huge piston in the 300zx calipers. So the gain would be small if any.
200sx don't bolt straight on you will still need to fabricate a bracket and get new disks as the 200sx disk diameter is larger than the R so again the std 14 wheels won't fit over the disks.
kyepan's right joining a group buy would make it far easier to upgrade the brake.
abelai
Calipers off the celica st205 bolt straight on (drill and tap hub m14 bolts required) so do r33 skyline calipers discs can then be made to spec from
www.rallydesign.co.uk
disc should be 300mm diameter and 30mm thick offset I am not sure about yet as they are comming off my old celica (st162)
Calipers should not cost more than £200 saw some sell for £150 the other day
