Rishi
Still waiting on some shims!
APEX Coilover Group Buy
We will order a shipment of the latest generation of Apex coilovers in Pulsar fitment in a couple of weeks time (Early Feb).
Coming by a boat to keep the discount as large as possible with around a 8-10 week delivery timescale from the order.
Delivery sometime in April (Japfest is in May)
We can spec with any spring rates but the GTiR test set were 5/4 which is a nice setup.
They are also fitted to Dasilva's GTiR thread is here
All Apex Performance coilovers come with a 10k miles 12 months warrenty against manufacturing defects and damper failure.
The coilovers on order are available with the following spring rates:
5kg/mm front
4kg/mm rear
OR - as you specify.
Ordering
The coilovers are available for Subaru, Evo, 200SX, Skyline as well as GTiR and can be also purchased on this group buy.
These new coilovers will retail at £649.
Ill do them at just £519.50 if we can get 6+ people involved
We can take a £80 non refundable deposit now with full payment when the units arrive with us.
We'll try and sort the ABS mounting point for the production run.
Contact:
Name: Kev @ APEX Performance
eMail: kev@apexperformance.co.uk
Tel: +44 (0)1274 683633
Fax: +44 (0)1274 683636
- New damper units with a wider range of adjustment
- Integrated bearing in front spring top platform to prevent spring binding and smooth out steering
- Lightweight bottom mounts to reduce unsprung weight
- 32 way click damping adjustable
- Modular design allows easy and cost effective servicing
- Various springs rates available, easy to change
- Spring platform adjustable for corner weight adjustment
- Ride height adjustable through bottom mount to retain full damper travel
- Ultra reliable brand, very low damper failure rates with full warrenty and after sales back up
- Pillowball front top mounts
- Camber adjustable front top mounts
- Rubber centred rear top mount for ultimate refinement
- Apex EDC Skyline
- Apex Time Attack S13 - SMs (1st rwd in class Time Attack Donny, 2nd rwd in class Time Attack Silverstone, 3rd rwd in TOTB)
- Apex Time Attack S13 - Yaks (2nd in class in rwd Time Attack Knockhill)
- Apex EDC S13 - Ian Harrison
- Apex EDC S13 - Kieran
- Apex Test S14a
- Apex Type RA Impreza
- Gary @ APTs 700+bhp Evo
- Team DCMS S14 - Graham
- Team DCMS S14a - Pete
5kg/mm front
4kg/mm rear
Ordering
Contact:
