Fuel drop off at 5k rpm
warringtonjack
Hi guys
Car is in process of being remapped at a tuner. He has discovered that the car starts running very lean at about 5k rpm, regardless of which boost pressure, etc the car is running. We're struggling to determine what is causing the fuelling drop off, so I'm after as many possible causes that could give such a consistent drop off at a given rpm, so that I can cross each one off.
As far as fuelling goes, the car has new 1000cc injectors, 390l/hr in tank pump, standard fuel rail, 3076R, z32maf. The tuner is mapping at 1.6Bar as a mid-range boost pressure.
Any advice gratefully received.
danr
warringtonjack
Should have mentioned that the car is running a PFC. Would the PFC also have an injector cut based on failed square wave signal?
I don't think it does. - When you said you were getting it mapped, I assumed this wasn't a standard ECU so the speedo cut wasn't your issue.
Could be wrong though.
danr
still an issue with nistune / plms or any other daughterboards that use standard ecu. but yeah stand alone wont have same safety feature, well, unless programmed/requested..
nismoboy
also just noticed your running a gt3076, have u increased the size of the standard fuel pipe? if not then thats your problem. But also re-wire the pump aswell.
