fitting a front mount intercooler
Does anyone know from experience what is the easiest way to move or remove the loop of pipe for cooling the power steering fluid that sits in front of the radiator[?][?]
Mulisha
If you are trying to put in a front mount, put the power steering "cooler" behind the hood latch support beam instead of it being in front of it. When you do this, remove the hood support, reverse the brakets fron left to right bolt the cooler into its original holes, bolt the support back together and it will be out of your way. Hope this helps. J
We race because other sports only require one ball
zia
depends what front you,ve gone for when i fitted my forge one i did,t have to move them at all.[:D]
zia
lord of the "R"
