do you have there number fellaSunny-D said:The 20v turbo discs will need the bolt holes elongating or ideally having the 4x100pcd re-drilled, Red-dot brakes supplied my discs with the new pcd for no extra charge!
Their number is 0870 3002354, as for the discs, i was using 315mm M3 discs with the Gti-r pcd.nimhbk said:do you have there number fella
did they do the bore hole as well
