ok just wondeing the factory boost guage is boosting off the scale while the after market one seems to go to ten
I agree with John - I don't think your after market gauge is calibrated... or at the least not reading the same boost source.
			but when i accelerate goes back to 0 seems weird to me .
Do you mean you're hard on the throttle and it just goes back to 0? That doesn't sound like it's reading boost at all... it is normal to read 0 when not accelerating though.
			what do the vacume pipes off an after market boost guage hook up to ?
 Mine is T-d into the same line as the factory gauge... which I think is also attached to the BOV and the boost sensor on my EVC - cunningly done so that they'd all read from the same source and be co-ordinated.
You can just about make it out in this picture: The yellowy T is connected to the after makrket gauge and the EVC; the black T is connected to the BOV and the factory sensor;
			also my temp guage and petrol level are not woring any ideas what this could be.
 Hmmm - could it be a loose connection behind the clocks? I can't remember if they are the same plug, but it wouldn't surprise me if they are.
			finally can see my o2 sensor is knackered would driving like this mess up my engine and does anyone know where i'd get one and would a sylvia one fit ? thanks very much for the help as i don't know a huge amount about these cars:shock:
 Are you running a standard ECU and map? I don't think it really likes not having an O2 reading and will likely over-fuel as a result. If you're not, you might be able to ignore it as not all the ECUs or maps take notice of what the lamda sensor is telling them (once the map is complete - obviously it's hard to set the A/F ratio without an lamda sensor).
I don't know about the sensor from a Silvia, but I would just google
lambda sensor nissan pulsar (or Sunny if you'd prefer). My search gave me "lambdasensor.co.uk" and "lambdapower.co.uk" both of which have a 3-wire 60-type connection sensor listed for the SR20DE at ~£86. - You can probably find cheaper if you search a little more than me... and more if you just go to Nissan and ask for one.
