AJ4
I'm still having major problems with squeal and metallic grinding noises, does anyone else suffer this ? Im using Willwood Polymatrix pads on Wilwood 280mm discs.
At first I thought it was just because they were new but they're well bedded in now and still squealing away. When cold they are fine, as soon as they warm up there is a high pitched squeal which then descends into the low metallic grinding noise.
I've built and rebuilt the whole setup, copperslip on the back of the pads and runners etc. and can't think what else to try.
Just wondered if anyone else is having the same problems or managed to cure the problem. Maybe its just the pads that are rubbish and need changing to another brand, dunno.
Ross.
Ross.
