gtir bean
it would seem that clio 172 front dusks are the correct stud pattern to fit the r.they are 280mm instead of 276 so they may need 2mm taken off the radius or just a bit out the carrier and a small washer between the carriers and the hub to space them out.they only cost about £80 from motor factors too.this is how they fit on colts(they can use them with evo disks by just redrilling them so it should be exactly the same for us.i think i will just get clio disks for mine to save drilling them.the centre bore may be slightly different but im not too sure.
