antgtir
The R lives again.
It turns out that the main electrical feed to the ignition block at the steering column had a drain of approx 0.5v from the battery to the block. So it seems there is a problem between those points.
To remove all possibilities of this re-occuring, a new positive line was routed to the ignition block. This removed the voltage drop and has solved the starting / flashing problem etc.
It seems the voltage drop associated with flashing your lights is large enough coupled with an unknown voltage drop along the line is enough to stop the car.
On with the preparations for the oc trackday.
Ant.
Ant.
